[gdal-dev] C#: Gdal on Win64
Tamas Szekeres szekerest at gmail.com
Fri Feb 29 05:51:17 EST 2008
Tomas,
Currently I have no opportunity to test on Vista 64 at the moment and
therefore I cannot decide whether this is a Vista specific issue or
not. I'm not sure which .NET framework you are running against. You
might want to do a test with my Windows Server 2003 x64 compilation
can be downloaded from the buildbot:
http://vbkto.dyndns.org:1080/gdal/szekerest-vc80-full/gdal/
I could also make the x64 versions of related dlls like proj.dll
available to download.
Best regards,
Tamas
2008/2/29, Tomas R <monshi at home.se>:
> Is it possible to use gdal (C# wrapped)  from FWTools on a Win64 system
>  (Vista 64)?
>  I have a plugin for SportTracks which gives other libraries access to
>  GDAL. This is achieved by adding the path to the GDAL binaries to system
>  PATH (for the running program).
>  On a Win64, i.e. Vista 64, the exception below is thrown when trying to
>  read the version of the GDAL libraries. Is this normal behaviour or is
>  there anything I can do to avoid this exception? I use GDAL 1.6.0dev
>  from FWTools 2.1.0. All supportive libraries from FWTools are available
>  to Gdal.
>  System.TypeInitializationException: The type initializer for
>  'OSGeo.GDAL.GdalPINVOKE' threw an exception. --->
>  'SWIGExceptionHelper' threw an exception. --->
>  System.BadImageFormatException: An attempt was made to load a program
>  with an incorrect format. (Exception from HRESULT: 0x8007000B)
>    at
>  OSGeo.GDAL.GdalPINVOKE.SWIGExceptionHelper.SWIGRegisterExceptionCallbacks_Gdal(ExceptionDelegate
>  applicationDelegate, ExceptionDelegate arithmeticDelegate,
>  ExceptionDelegate divideByZeroDelegate, ExceptionDelegate
>  indexOutOfRangeDelegate, ExceptionDelegate invalidOperationDelegate,
>  ExceptionDelegate ioDelegate, ExceptionDelegate nullReferenceDelegate,
>  ExceptionDelegate outOfMemoryDelegate, ExceptionDelegate
>  overflowDelegate, ExceptionDelegate systemExceptionDelegate)
>    at OSGeo.GDAL.GdalPINVOKE.SWIGExceptionHelper..cctor()
>    --- End of inner exception stack trace ---
>    at OSGeo.GDAL.GdalPINVOKE.SWIGExceptionHelper..ctor()
>    at OSGeo.GDAL.GdalPINVOKE..cctor()
>    at OSGeo.GDAL.GdalPINVOKE.SetConfigOption(String jarg1, String jarg2)
>    at OSGeo.GDAL.Gdal.SetConfigOption(String arg0, String arg1)
>    at GDALPlugin.Gdal_Interface..ctor()
>  Yours
>  Tomas
>  _______________________________________________
>  gdal-dev mailing list
>  gdal-dev at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
