[gdal-dev] Re: C#: Gdal on Win64
Tamas Szekeres szekerest at gmail.com
Fri Feb 29 07:12:16 EST 2008
Grrr.  I've posted a reference to the x32 builder, here are the correct ones:
http://vbkto.dyndns.org:1080/gdal/szekerest-vc80x64-full/gdal/
http://vbkto.dyndns.org:1080/gdal/szekerest-vc80x64-bin
Best regards,
Tamas
2008/2/29, Tomas R <monshi at home.se>:
> Neither have I access to a computer with Vista 64, or any other 64 bit
>  system, it is a user who has reported the error. I'm waiting to see if
>  there will be another user with a 64 bit system who will test the plugin
>  so as you say, it is not yet confirmed it is a 64 bit error.
>  The plugin is compiled to .Net2.0 and, of course on Vista, run on .Net3.5.
>  Since I personally can't test it is a bit harder/slower to verify if it
>  works.  A quick test on my computer (Win XP, 32 bit), after renaming the
>  gdal16dev.dll to gdal_fw.dll, together with FWTools C# wrappers and
>  supporting libraries I am able to query the gdal version but not, with
>  existing code, set up a spatial reference. (Pinvoke error, Can't read
>  the DLL-file osr_wrap)
>  Strange - is it a 64 bit "version" of gdal? should it then at all work
>  on my 32 bit system? That it fails on setting up a spatial reference I
>  guess is because it it is not able to reference to the FWtools version
>  of the supporting dlls. Or?
>  I will see if the user is willing to try this dll I downloaded from your
>  link and see if he is able to retrieve version information. If that
>  works we can move on to the rest of the libraries if you are willing.
>  Yours
>  Tomas
>  Tamas Szekeres skrev:
> > Tomas,
>  > Currently I have no opportunity to test on Vista 64 at the moment and
>  > therefore I cannot decide whether this is a Vista specific issue or
>  > not. I'm not sure which .NET framework you are running against. You
>  > might want to do a test with my Windows Server 2003 x64 compilation
>  > can be downloaded from the buildbot:
>  > http://vbkto.dyndns.org:1080/gdal/szekerest-vc80-full/gdal/
>  > I could also make the x64 versions of related dlls like proj.dll
>  > available to download.
>  > Best regards,
>  > Tamas
> > 2008/2/29, Tomas R :
>  >> Is it possible to use gdal (C# wrapped)  from FWTools on a Win64 system
>  >>  (Vista 64)?
>  >>  I have a plugin for SportTracks which gives other libraries access to
>  >>  GDAL. This is achieved by adding the path to the GDAL binaries to system
>  >>  PATH (for the running program).
>  >>  On a Win64, i.e. Vista 64, the exception below is thrown when trying to
>  >>  read the version of the GDAL libraries. Is this normal behaviour or is
>  >>  there anything I can do to avoid this exception? I use GDAL 1.6.0dev
>  >>  from FWTools 2.1.0. All supportive libraries from FWTools are available
>  >>  to Gdal.
>  >>  System.TypeInitializationException: The type initializer for
>  >>  'OSGeo.GDAL.GdalPINVOKE' threw an exception. --->
>  >>  'SWIGExceptionHelper' threw an exception. --->
>  >>  System.BadImageFormatException: An attempt was made to load a program
>  >>  with an incorrect format. (Exception from HRESULT: 0x8007000B)
>  >>    at
>  >>  OSGeo.GDAL.GdalPINVOKE.SWIGExceptionHelper.SWIGRegisterExceptionCallbacks_Gdal(ExceptionDelegate
>  >>  applicationDelegate, ExceptionDelegate arithmeticDelegate,
>  >>  ExceptionDelegate divideByZeroDelegate, ExceptionDelegate
>  >>  indexOutOfRangeDelegate, ExceptionDelegate invalidOperationDelegate,
>  >>  ExceptionDelegate ioDelegate, ExceptionDelegate nullReferenceDelegate,
>  >>  ExceptionDelegate outOfMemoryDelegate, ExceptionDelegate
>  >>  overflowDelegate, ExceptionDelegate systemExceptionDelegate)
>  >>    at OSGeo.GDAL.GdalPINVOKE.SWIGExceptionHelper..cctor()
>  >>    --- End of inner exception stack trace ---
>  >>    at OSGeo.GDAL.GdalPINVOKE.SWIGExceptionHelper..ctor()
>  >>    at OSGeo.GDAL.GdalPINVOKE..cctor()
>  >>    at OSGeo.GDAL.GdalPINVOKE.SetConfigOption(String jarg1, String jarg2)
>  >>    at OSGeo.GDAL.Gdal.SetConfigOption(String arg0, String arg1)
>  >>    at GDALPlugin.Gdal_Interface..ctor()
>  >>  Yours
>  >>  Tomas
>  >>  _______________________________________________
>  >>  gdal-dev mailing list
>  >>  gdal-dev at lists.osgeo.org
>  >>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
