[gdal-dev] Gdalwarp speed comparison
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Fri Feb 29 09:42:43 EST 2008
I made some time ago a few measurements about the speed in of reprojecting
images with gdalwarp and and another software.  Results can be found from here:
http://forums.ermapper.com/viewtopic.php?t=2889
Another software had an option to use an option called "Speed optimization"
which had a big effect on speed. It believe it relates somehow to warping either
in bigger blocks or pixel-by-pixel. I wonder if gdalwarp is utilising something
similar because it tends to be so fast?
-Jukka Rahkonen-
