[gdal-dev] Python ReadAsArray problem
Lucena, Ivan ivan.lucena at pmldnet.com
Fri Feb 29 14:52:16 EST 2008
My mistake.
I should have used:
 > python setup.py bbuild_windist
 > dist\GDAL-1.5.0.win32-py2.4.exe
Now it works perfectly.
Ivan
Lucena, Ivan wrote:
> Hi there,
> I am running into a problem with ReasAsArray().
> When I try to run it I got:
> "ImportError: No module named _gdal_array"
> Here is my stuff:
> Python 2.4.1
> Python 2.4 GDAL-1.5.0b1 (*)
> Python 2.4 numpy-1.0.4
> I build the GDAL Python extension from the latest trunk update:
>  > python setup.py build
>  > dist\GDAL-1.5.0b1.win32-py2.4.exe
> Best regards,
> Ivan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
