[gdal-dev] Re: C#: Gdal on Win64
Tomas R monshi at home.se
Fri Feb 29 16:12:19 EST 2008
Sad to say, same error occured with these dlls. I renamed them to
gdal_fw.dll and proj_fw.dll and also kept a copy of proj.dll with
original name and told the user to overwrite the existing ones.
Same error.
I will not say it is a Vista problem, or a 64-bit problem, until I have
a confirmation from someone else.
If anyone here, with a 64-bit system (Vista, XP or Server 2003),  is
willing to give it a try:
1: Install SportTracks
http://www.zonefivesoftware.com/SportTracks/
2: Install my GDAL-plugin
http://mapplugin.googlepages.com/gdal
Start SportTracks, go to the settings view. Locate the plugin and check
if it is installed correctly. Version info should be displayed.
Yours
Tomas
Tamas Szekeres skrev:
> Grrr.  I've posted a reference to the x32 builder, here are the correct ones:
> http://vbkto.dyndns.org:1080/gdal/szekerest-vc80x64-full/gdal/
> http://vbkto.dyndns.org:1080/gdal/szekerest-vc80x64-bin
> Best regards,
> Tamas
> 2008/2/29, Tomas R <monshi at home.se>:
>> Neither have I access to a computer with Vista 64, or any other 64 bit
>>  system, it is a user who has reported the error. I'm waiting to see if
>>  there will be another user with a 64 bit system who will test the plugin
>>  so as you say, it is not yet confirmed it is a 64 bit error.
>>  The plugin is compiled to .Net2.0 and, of course on Vista, run on .Net3.5.
>>  Since I personally can't test it is a bit harder/slower to verify if it
>>  works.  A quick test on my computer (Win XP, 32 bit), after renaming the
>>  gdal16dev.dll to gdal_fw.dll, together with FWTools C# wrappers and
>>  supporting libraries I am able to query the gdal version but not, with
>>  existing code, set up a spatial reference. (Pinvoke error, Can't read
>>  the DLL-file osr_wrap)
>>  Strange - is it a 64 bit "version" of gdal? should it then at all work
>>  on my 32 bit system? That it fails on setting up a spatial reference I
>>  guess is because it it is not able to reference to the FWtools version
>>  of the supporting dlls. Or?
>>  I will see if the user is willing to try this dll I downloaded from your
>>  link and see if he is able to retrieve version information. If that
>>  works we can move on to the rest of the libraries if you are willing.
>>  Yours
>>  Tomas
>>> Tomas,
>>  > Currently I have no opportunity to test on Vista 64 at the moment and
>>  > therefore I cannot decide whether this is a Vista specific issue or
>>  > not. I'm not sure which .NET framework you are running against. You
>>  > might want to do a test with my Windows Server 2003 x64 compilation
>>  > can be downloaded from the buildbot:
>>  > http://vbkto.dyndns.org:1080/gdal/szekerest-vc80-full/gdal/
>>  > I could also make the x64 versions of related dlls like proj.dll
>>  > available to download.
>>  > Best regards,
>>  > Tamas
>>> 2008/2/29, Tomas R :
>>  >> Is it possible to use gdal (C# wrapped)  from FWTools on a Win64 system
>>  >>  (Vista 64)?
>>  >>  I have a plugin for SportTracks which gives other libraries access to
>>  >>  GDAL. This is achieved by adding the path to the GDAL binaries to system
>>  >>  PATH (for the running program).
>>  >>  On a Win64, i.e. Vista 64, the exception below is thrown when trying to
>>  >>  read the version of the GDAL libraries. Is this normal behaviour or is
>>  >>  there anything I can do to avoid this exception? I use GDAL 1.6.0dev
>>  >>  from FWTools 2.1.0. All supportive libraries from FWTools are available
>>  >>  to Gdal.
>>  >>  System.TypeInitializationException: The type initializer for
>>  >>  'OSGeo.GDAL.GdalPINVOKE' threw an exception. --->
>>  >>  'SWIGExceptionHelper' threw an exception. --->
>>  >>  System.BadImageFormatException: An attempt was made to load a program
>>  >>  with an incorrect format. (Exception from HRESULT: 0x8007000B)
>>  >>    at
>>  >>  OSGeo.GDAL.GdalPINVOKE.SWIGExceptionHelper.SWIGRegisterExceptionCallbacks_Gdal(ExceptionDelegate
>>  >>  applicationDelegate, ExceptionDelegate arithmeticDelegate,
>>  >>  ExceptionDelegate divideByZeroDelegate, ExceptionDelegate
>>  >>  indexOutOfRangeDelegate, ExceptionDelegate invalidOperationDelegate,
>>  >>  ExceptionDelegate ioDelegate, ExceptionDelegate nullReferenceDelegate,
>>  >>  ExceptionDelegate outOfMemoryDelegate, ExceptionDelegate
>>  >>  overflowDelegate, ExceptionDelegate systemExceptionDelegate)
>>  >>    at OSGeo.GDAL.GdalPINVOKE.SWIGExceptionHelper..cctor()
>>  >>    --- End of inner exception stack trace ---
>>  >>    at OSGeo.GDAL.GdalPINVOKE.SWIGExceptionHelper..ctor()
>>  >>    at OSGeo.GDAL.GdalPINVOKE..cctor()
>>  >>    at OSGeo.GDAL.GdalPINVOKE.SetConfigOption(String jarg1, String jarg2)
>>  >>    at OSGeo.GDAL.Gdal.SetConfigOption(String arg0, String arg1)
>>  >>    at GDALPlugin.Gdal_Interface..ctor()
>>  >>  Yours
>>  >>  Tomas
>>  >>  _______________________________________________
>>  >>  gdal-dev mailing list
>>  >>  gdal-dev at lists.osgeo.org
>>  >>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
