[gdal-dev] netCDF to GRIB 1
Mateusz Loskot mateusz at loskot.net
Tue Jan 1 15:42:52 EST 2008
Mateusz Loskot wrote:
> John L. Craddock wrote:
>> Hello all,
>> Been scanning the ether for windows code to convert ocean current files
>> in netCDF format to GRIB version 1. I know about GRADS and the lats4d
>> script. Thought I would ask here if anyone knows of a less circuitous
>> way of converting. I see GDAL reads netCDF. Is there a driver to output
>> GRIB?
> John,
> There is GRIB driver in the GDAL spike repository:
> https://svn.osgeo.org/gdal/spike/grib/
> You may try to checkout it and build into GDAL.
BTW, here you can find short instructions how to build GDAl with GRIB
support (the SVN URL given there is not active anymore, use the new one
above):
http://lists.osgeo.org/pipermail/gdal-dev/2007-February/011663.html
Mateusz Loskot
http://mateusz.loskot.net
