[gdal-dev] ogr2ogr - create an IND file during MapInfo file export
Fri Jan 4 12:24:02 EST 2008
Guilhem Vellut wrote:
> Hello,
> I would like to translate a SHP to a Mapinfo TAB file using ogr2ogr.
> On top of obtaining the usual files (ID, MAP, TAB and DAT), I also
> want to get an index on an attribute (MapInfo Pro creates an IND file
> for that) but, if it is possible, I cannot find a mention of how to do
> it in the doc. Does ogr2ogr have an option to create this IND file ?
> Thanks in advance for any help.
Guilhem,
I'm sorry, but ogr2ogr does not appear to support creating .ind files
for mapinfo datasets.  The capability does exist in the underlying MITAB
library so if you wanted it badly enough you might be able to modify the
mapinfo driver, or perhaps build a custom mitab utility to do this.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
