[gdal-dev] Shapefile to Lambert Azimuthal Equal Area
Ed McNierney ed at topozone.com
Mon Jan 7 11:48:05 EST 2008
Kent -
The obvious question would be, "And do you think code 9820 actually exists in your EPSG file?".  There is no such projection code in my EPSG table from PROJ.
What projection definition do you think EPSG:9820 describes?
     - Ed
Ed McNierney
Chief Mapmaker
Demand Media / TopoZone.com
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Kent Eschenberg
Sent: Monday, January 07, 2008 11:29 AM
To: GDAL
Subject: [gdal-dev] Shapefile to Lambert Azimuthal Equal Area
Any idea why I cannot convert a shapefile to the Lambert azimuthal equal area
projection? I tried
ogr2ogr -t_srs EPSG:9820 -f "ESRI Shapefile" destination.shp source.shp
and saw the message
ERROR 6:
EPSG PCS/GCS code 9820 not found in EPSG support files.  Is this a valid
EPSG coordinate system?
Failed to process SRS definition: EPSG:9820
I'm using GDAL 1.4.2 on Fedora core 6.
TIA!
Kent
Pittsburgh Supercomputing Center
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
