[gdal-dev] Java SWIG Bindings
Meek, Allan (Contractor)
Allan.Meek at drdc-rddc.gc.ca
Tue Jan 8 15:45:03 EST 2008
Thanks for your help, Ben. With Daniele's document and your suggestions,
I've managed to get everything up and running in both Linux and Windows.
Thanks,
Allan
-----Original Message-----
From: Collins, Benjamin [mailto:collinsb at mitre.org]
Sent: January 7, 2008 3:06 PM
To: Meek, Allan (Contractor)
Cc: gdal-dev at lists.osgeo.org
Subject: RE: [gdal-dev] Java SWIG Bindings
>From: gdal-dev-bounces at lists.osgeo.org
>[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Meek,
>Allan (Contractor)
>Sent: Monday, January 07, 2008 12:59 PM
>To: gdal-dev at lists.osgeo.org
>Subject: [gdal-dev] Java SWIG Bindings
> (from {...}/swig/java/apps)
> java -cp ../gdal.jar -Djava.library.path=../.libs/ gdalinfo
> Exception in thread "main" java.lang.NoClassDefFoundError: gdalinfo
You may need to specify -cp .:../gdal.jar to get java to look at your
local folder for class files.
>If I remove "-cp ../gdal.jar", ...
Please don't do this.
