[gdal-dev] Open source API to convert raster to polygons?
Joaquim Luis jluis at ualg.pt
Wed Jan 9 15:11:07 EST 2008
Ari Jolma wrote:
> Ricardo Scachetti Pereira kirjoitti:
>>    Hi all,
>>      Does anyone know of any open source geoprocessing APIs that I
>> can use to convert raster maps into polygons (as a shapefile or SQL
>> for PostGIS)? Does QGIS do that?
>>    I know that GDAL (via gdal_contour utility) can turn a raster into
>> lines, but that's not good enough for me. I need closed polygons that
>> I later intend to import into PostGIS. Gdal_contour would give usable
>> intermediate results (i.e, it produces lines that I think can be
>> turned into closed polygons), if it wasn't for the open polygons that
>> are created where the grid values touch NODATA values.
>>    I have considered using GRASS (r.poly) but I need to embed the
>> geoprocessing library on an research application that I will deploy
>> to Windows desktop computers. To be completely honest, I can't even
>> install  GRASS on my Windows workstation, so I have no hopes of
>> deploying it via a neat installer :(( . That's probably due to the
>> lack of intelligence and patience, and is another story.
>>    Any help with this would be greatly appreciated.
> Dear Ricardo,
> I've written a raster to polygon converter, which produces closed
> polygons from raster images. The algorithm is not speed optimized nor
> proven correct but quite ok. The polygons are OGR features and can
> thus be saved to PostGIS. This is, however, a method that I've written
> in Perl for the Geo::Raster class, which is a Perl interface to an
> in-memory libral raster. On the other hand, the Geo::Raster class
> contains methods to make or clip the raster from a raster opened with
> GDAL. These tools are available as Windows versions (the latest zip
> from http://map.hut.fi/files/Geoinformatica/snapshots/ which contains
> DLLs of the libraries and perl.exe and lots of Perl code).
I am sorry but I have some difficulties in understanding this discussion.
What is a raster to polygon conversion?
I know, and have played with, vectorizing edge detected images, shape
detection of simple forms like ellipses, lines, ridge crests on DTMs etc...
but for each of these goals the tools/algorithms used are different.
What I do not understand is what is a generic "raster to polygon
conversion".
Joaquim Luis
