[gdal-dev] using gdal_translate with -dsco switch
Brian Hamlin maplabs at light42.com
Wed Jan 9 17:05:23 EST 2008
I think altitudeMode is for ogr2ogr using the KML driver.. thats where
I have used it
  -Brian
On Jan 9, 2008, at 1:33 PM, Dane Springmeyer wrote:
> I am converting elevation data in Gtiff format to contours in KML
> format, but running into a usage problem when attempting to create 3D
> contours.
> I noted the discussion here about enabling correct 3D representation
> in Google Earth (This is a great addition):
> http://trac.osgeo.org/gdal/ticket/1570
> and the need to use driver specific name=value option for ogr2ogr of
> "-dsco AltitudeMode=absolute" here:
> http://www.gdal.org/ogr/drv_kml.html
> When I attempt to use it with gdal_translate the utility simply
> returns the usage instructions. I'm guessing that either I am putting
> the flag in the wrong place or this option is not enabled in
> gdal_contour, even though I am able to successfully write KML with
> gdal_contour.
> I'm running GDAL 1.5.0b2 on mac os x. This works for me:
> gdal_contour -f KML -i 5.0 blakely.tif five_meter_contours.kml
>       //Note: the -3d switch is left out intentionally since it does
> not seem to affect KML output
> These do not:
> gdal_contour -f KML -i 5.0 blakely.tif five_meter_contours.kml -dsco
> gdal_contour -f KML -dsco AltitudeMode=absolute -i 5.0
> Anyone have ideas of the problem?
> Regards,
> Dane
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
