[Gdal-dev] JP2MrSID driver. How to get it?
Thu Jan 10 11:45:14 EST 2008
Daniele Romagnoli wrote:
> Hi,
> I'm working on LINUX (Ubuntu) to fix some things on ImageIo-ext project.
> I have read some olds threads talking about conflicts between Kakadu and
> MrSID's Jpeg2000 support.
> I'm using GDAL 1.4.2 with MrSid (GeoExpress Decode SDK 6.0.7.1407) and
> Kakadu 5.2.6.
> When building GDAL after configuring it for MrSid and Kakadu, I get only
> JP2KAK and MrSID (using GDALInfo --formats).
> I then attempted to edit GDALMake.opt after ./configure, adding
> MRSID_FLAGS =   -DMRSID_J2K and I get errors when building.
> However I have noticed that when configuring with support for only
> MrSID, JP2MrSID appears in the list of supported formats (So, manually
> setting MRSID_FLAGS is not required :P)
> It is possible to support both JP2KAK and JP2MRSID driver on Linux?
> Thanks a lot.
Daniele,
I see MRSID_J2K is deliberately excluded by configure if Kakadu is being
built in.  I don't recall all the details, but the MrSID libraries include
a variant of Kakadu as I understand resulting in (apparently) various kinds
of symbol conflict problems.
When MRSID_J2K is defined, -lltikdu is also added to the link libraries.  If
you added this you could likely at least experiement with having both enabled
at the same time.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
