[gdal-dev] Re: gdal_merge multiple files
Mullins, Steven Steven.Mullins at dmme.virginia.gov
Thu Jan 10 12:20:42 EST 2008
That was it... --optfile.  I used that before but could not remember it.
Thanks!
Steve
-----Original Message-----
From: estrada.adam at gmail.com [mailto:estrada.adam at gmail.com]
Sent: Thu, January 10, 2008 10:20 AM
To:
Subject: [gdal-dev] Re: gdal_merge multiple files
Steve,
    I am using FWTools version 2.0.3 and the following command line
seems to work just fine.
python gdal_merge.py -n 0 -o \\fscluster\Images\Archive\Images
\31\mosaic_31.tif -of GTiff -co "TFW=YES" -v --optfile \\fscluster
\Images\Archive\Images\31\31.txt
The text file is a directory list that I created in Windows by typing
[ dir /b /s *.tif > 31.txt ]
I hope this helps.
AWE
On Jan 10, 8:34 am, "Mullins, Steven"
<Steven.Mull... at dmme.virginia.gov> wrote:
> It seems that gdal_merge does not like globbing.  Are there other ways of getting a list of images into gdal_merge without putting them all on the command line?  I think I did this once before with a similar gdal command but used a config file???
> Steve
> gdal-dev mailing list
> gdal-... at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
