[gdal-dev] converting csv to kml: locations displaced in GoogleEarth
Brian Hamlin maplabs at light42.com
Thu Jan 10 18:15:44 EST 2008
This cries out for a small custom script!
Simple csv in is a very common case for an end user.. , with all points
in Lat/Lon.. or better Lon/La
The Google python tool Regionator will handle it also
On Jan 10, 2008, at 2:55 PM, Dane Springmeyer wrote:
> Even and Chris -
> Great, thanks for the clarification! That makes perfect sense now that
> I understand the idea behind a VRT file.
> I think the current non-trac documentation is great but would benefit
> from spelling out that the VRT datasource is made by hand - just like
> Even mentioned.
> For new users it might be helpful to have these steps in a tutorial
> somewhere. I could write that up quickly - where might be the best
> place to put it?  Maybe a "How do I convert CSV to KML?" in this spot:
> http://trac.osgeo.org/gdal/wiki/FAQVector
> Is there a spot on trac for driver specific info that I could help out
> with adding info to as well?
> Thanks,
> Dane
> On Jan 10, 2008, at 2:38 PM, Christopher Condit wrote:
>> Just to clear this up if it isn't already: if the CSV file in
>> question is called "test.csv" and I create a separate VRT file called
>> "test.vrt" (in the same directory as "test.csv") with the following
>> content:
>> <OGRVRTDataSource>
>>     <OGRVRTLayer name="test">
>>         <SrcDataSource>test.csv</SrcDataSource>
>>         <GeometryType>wkbPoint</GeometryType>
>>         <LayerSRS>WGS84</LayerSRS>
>>         <GeometryField encoding="PointFromColumns" x="Longitude"
>> y="Latitude"/>
>>     </OGRVRTLayer>
>> </OGRVRTDataSource>
>> I can then treat the test.vrt file as a read-only OGR data source.
>> And when I run the transform:
>> ogr2ogr -f KML test.kml test.vrt
>>  I end up with:
>> <?xml version="1.0" encoding="utf-8" ?>
>> <kml xmlns="http://earth.google.com/kml/2.0">
>> <Document><Folder><name>test</name>
>>   <Placemark>
>>       <name>First point</name>
>>       <description>
>> <![CDATA[
>>       <b>Latitude:</b> <i>48.1</i><br />
>>       <b>Longitude:</b> <i>0.25</i><br />
>> ]]></description>
>>       <Point><coordinates>0.25,48.1,0</coordinates></Point>
>>   </Placemark>
>>   <Placemark>
>>       <name>Second point</name>
>>       <description>
>> <![CDATA[
>>       <b>Latitude:</b> <i>49.2</i><br />
>>       <b>Longitude:</b> <i>1.1</i><br />
>> ]]></description>
>> <Point><coordinates>1.1,49.200000000000003,0</coordinates></Point>
>>   </Placemark>
>>   <Placemark>
>>       <name>Third point</name>
>>       <description>
>> <![CDATA[
>>       <b>Latitude:</b> <i>47.5</i><br />
>>       <b>Longitude:</b> <i>0.75</i><br />
>> ]]></description>
>>       <Point><coordinates>0.75,47.5,0</coordinates></Point>
>>   </Placemark>
>> </Folder></Document></kml>
>> Even - I think the documentation is straightforward...
>> -Chris
>> -----Original Message-----
>> From: gdal-dev-bounces at lists.osgeo.org
>> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Even Rouault
>> Sent: Thursday, January 10, 2008 14:32
>> To: Dane Springmeyer
>> Cc: gdal-dev at lists.osgeo.org
>> Subject: Re: [gdal-dev] converting csv to kml: locations displaced in
>> GoogleEarth
>> Dane,
>> I'm the one who wrote that part of the CSV doc indeed...
>> Sorry that it's not clearer. What I meant by "You can write the
>> associated VRT
>> file (test.vrt)" is indeed "You must create at hand an associated VRT
>> file
>> (test.vrt)". You create it at hand, and then gives it as an input to
>> OGR, so
>> it can understand the structure of the underlying CSV file. I hope it
>> makes
>> things clearer...
>> If people have suggestions to formulate it more clearly in the docs,
>> let me
>> know.
>> Best regards
>> Le Thursday 10 January 2008 23:09:01, vous avez écrit :
>>> Hi Even,
>>> the csv to vrt docs here: http://www.gdal.org/ogr/drv_csv.html
>>> say to "write" a vrt but from the format's list and the error message
>>> I get it seems VRT is still read-only in Gdal 1.5
>>> Am I missing something?
>>> I get:
>>> ____
>>> [tropicana]$ ogr2ogr -f VRT test.vrt test.csv
>>> VRT driver does not support data source creation.
>>> ____
>>> - dane
>>> On Jan 10, 2008, at 1:19 PM, Even Rouault wrote:
>>>> Answers below :
>>>> Le Thursday 10 January 2008 21:54:09 Tim Michelsen, vous avez écrit
>>>>> Hello,
>>>>> I would like to convert a csv file to kml. When I load the
>>>>> resulting KML
>>>>> into Googleearth (GE) the generated placemarks inside the file are
>>>>> totally displaced.
>>>>> What could be the reason?
>>>>> Could it be that XML decription is used too old?
>>>>> When I export my places from GE I read this line:
>>>>> <kml xmlns="http://earth.google.com/kml/2.1">
>>>>> In the generated KML file I can read:
>>>> OGR KML driver exports KML 2.0 for the moment, but that shouldn't
>>>> be a
>>>> problem.
>>>>> Here are the test files:
>>>>> Latitude,Longitude,Name
>>>>> 48.1,0.25,"First point"
>>>>> 49.2,1.1,"Second point"
>>>>> 47.5,0.75,"Third point"
>>>>> the command line I used:
>>>>> ogr2ogr -f "KML" test.kml test.csv
>>>>> the KML:
>>>>>      <Placemark>
>>>>>        <description><![CDATA[
>>>>>          <b>Name:</b> <i>First point</i><br />
>>>>>       ]]></description>  </Placemark>
>>>>>      <Placemark>
>>>>>          <b>Name:</b> <i>Second point</i><br />
>>>>>      <Placemark>
>>>>>          <b>Name:</b> <i>Third point</i><br />
>>>> The generated KML file is obviously not what you would expect (it
>>>> has output
>>>> all the CSV fields into the description tag, and GE by default put
>>>> such
>>>> placemark at (0°,0°), which is at the west of Africa) . But that
>>>> can be
>>>> logically explained. You can't use a CSV file as simply as you do.
>>>> If you
>>>> read more carefully http://www.gdal.org/ogr/drv_csv.html, you'll
>>>> see that you
>>>> need to create a VRT file, test.vrt, and do ogr2ogr on that file,
>>>> not on the
>>>> original CSV file.
>>>>> Attached you find the screenshot from GE.
>>>>> I would highly appreciate your hints and help.
>>>>> Kind regards,
>>>>> Timmie
>>>>> P.S. The Mailserver would let my inital mail through. This one
>>>>> comes
>>>>> with a smaller image.
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
