[gdal-dev] gdalwarp creates a bloated file
Matt Wilkie matt.wilkie at gov.yk.ca
Thu Jan 10 18:09:32 EST 2008
> Wonderful and thanks for pointing that out! gdal 1.5 did the trick.
> The file size is down from 218.5MB to 3.9MB.
for anybody who can't upgrade to 1.5 for some reason, if you recompress
the bloated result with gdal_translate the image goes down to a
reasonable size.  Eg:
   gdalwarp ... gdalwarp-result.tif
   gdal_translate -co compress=lzw gdalwarp-result.tif final-result.tif
Actually it's better not to compress with gdalwarp at all in this
circumstance as that just slows it down, doing work for nothing.
Possibly related bug tickets:
gdalwarp creates GeoTIFFs bigger than gdal_translate -
http://trac.osgeo.org/gdal/ticket/1688
gdalwarp -co "COMPRESS=DEFLATE" output 45% too big -
http://trac.osgeo.org/gdal/ticket/1689
gdalwarp with pixel interleave, resample, and compress makes huge files
- http://trac.osgeo.org/gdal/ticket/1470
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
