[gdal-dev] GDAL plugins and ArcGIS 9.2
Lucena, Ivan ivan.lucena at pmldnet.com
Thu Jan 10 19:53:23 EST 2008
John,
If you search the gdal-dev archives you will find what Peng Gao (ESRI's)
has to say about that. He said that it is possible but unlikely to work
due to customization on their end. What I suggest is that as ESRI
business partner (EDN member or some other kind of arrangement) you
might be able to get the gdal_1.lib; their additional or modified .h(s)
and some epsg_*.inc(s) files and use VC71, MSVS 2003, to build a GDAL14
plugin.
Regards,
Ivan
Frank Warmerdam wrote:
> John Edwards wrote:
>> Is there a branch of GDAL that was used for ArcGIS 9.2?  I’m trying
>> unsuccessfully to create a plugin for use in ArcGIS and wondering if
>> the source code that built ESRI’s version of gdal13.dll is available.
> John,
> There is no specific ArcGIS branch off GDAL 1.3. In theory I think you
> should be able to build a plugin using MSVC 7.0 (aka MS Visual Studio 2002
> .NET) and any of the GDAL 1.3.x releases.  In practice I'm not sure if
> there are particular options required.
> I'll leave a more comprehensive response to others who know more about
> this.
> Best regards,
