[gdal-dev] Troubles buiding svn version on windows
Joaquim Luis jluis at ualg.pt
Mon Jan 14 12:24:39 EST 2008
I'm having problem to build the snv version on Windows. Here is a short
log of the errors.
The last time that updated was about 19 December and had no building
problems than.
Joaquim Luis
     D:\progs_interix\netcdf-3.6.2b5_win\lib\libnetcdf.lib
D:\prog
ramas\curl-7.15.1/libcurl_imp.lib wsock32.lib wldap32.lib winmm.lib
gcore\Versi
on.res  /out:gdal16dev.dll /implib:gdal_i.lib
cpl_path.obj : warning LNK4044: unrecognized option
"alternatename:__imp_??$?9DU
?$char_traits at D@std@@V?$allocator at D@1@@std@@YA_NABV?$basic_string at DU?$char_trait
s at D@std@@V?$allocator at D@2@@0 at PBD@Z=__imp_??9std@@YA_NABV?$basic_string at DU?$char_
traits at D@std@@V?$allocator at D@2@@0 at PBD@Z"; ignored
s at D@std@@V?$allocator at D@2@@0 at 0@Z=__imp_??9std@@YA_NABV?$basic_string at DU?$char_tr
aits at D@std@@V?$allocator at D@2@@0 at 0@Z"; ignored
more of this stuff ....
LINK : fatal error LNK1104: cannot open file "atls.lib"
