[gdal-dev] Re: Motion: Adopt RFC 20: OGRSpatialReference Axis Support
Andrey Kiselev dron at ak4719.spb.edu
Tue Jan 15 02:03:49 EST 2008
On Mon, Jan 14, 2008 at 11:54:36PM -0500, Frank Warmerdam wrote:
>  The CPL config option "IGNORE_AXIS_ORIENTATION" may also be set to
>  "TRUE" to disable OGRCoordinateTransformation's checking, and
>  application of axis orientation changes. Effectively this is a
>  backdoor to disable the core effects of the RFC.
Frank,
Do we have any convention on GDAL option naming? Some of them starts
with "GDAL_" prefix, but this one not. I am suggesting to rename it in
"GDAL_IGNORE_AXIS_ORIENTATION" to be more uniform and clear.
Best regards,
Andrey
Andrey V. Kiselev
ICQ# 26871517
