[gdal-dev] Urgent clarification needed.
Brent Fraser bfraser at geoanalytic.com
Wed Jan 16 23:50:09 EST 2008
Chris,
 There's a ODBC setting in GDAL's nmake.opt file:
# Comment out the following to disable ODBC support.
ODBC_SUPPORTED = 1
So by default it is supported...
Brent Fraser
> We're having some difficulty opening a client's database file via the
> ordinary OGR reader, therefore I was reading the documentation found at.
> http://www.gdal.org/ogr/drv_odbc.html in reference to using the ODBC,
> the documentation states that this is potentially available in both
> unix/windows builds. However only available in unix by special
> compilation options. My question is, is this driver available in windows
> without the need for any special compiliation options or do I have to do
> something special to get it ?
> Cheers
> Chris
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
