[gdal-dev] Re: Open source API to convert raster to polygons? ( Roger Andr? )
Dan Stahlke dstahlke at gi.alaska.edu
Fri Jan 18 18:41:13 EST 2008
I have a C program that will create a polygon around the non-zero pixels
of an image.  It was written for Unix so I don't know how hard it would
be to get it to compile in Windows.  The program is fast though - the
reading of the image from disk takes as long as the actual polygon
tracing.  There are many options available including the ability to use
the Douglas-Peucker algorithm to reduce the number of points in the
polygon.  Output is in WKT format and can be either in the projection of
the source image or in longitude/latitude.  Here is the link to the
source code:
http://www.gina.alaska.edu/page.xml?group=projects&page=gdalscripts
gdal-dev-request at lists.osgeo.org wrote:
> Hi Ricardo,
> I had to do the same thing yesterday and wrote the script that's
> attached here.  It will read a raster data file and create a polygon
> for each pixel that does not have a value of 0.0.  The input, output
> and pixel value are all hard-coded, and the script is pretty crude,
> but it seems to work.  I'll warn you ahead of time that the shapefiles
> it creates are large, with a very high feature count. Oh, and I make
> no attempt to assign SRS, the shapefile will be in whatever projection
> the input raster is in.
> Hope that helps,
> Roger
> PS - If anyone else reads this and has suggestions for optimizing
> performance, I would really welcome them.
