[gdal-dev] OGR style fields
Stefan Keller sfkeller at gmail.com
Sat Jan 19 12:03:01 EST 2008
About two weeks ago I proposed in the FWTools list to enable users of
OGR/GDAL tools like ogr2ogr to set the style parameters from the command
line or using .VRT. This would be a valuable extension for writing KML
files.
Any views about this?
Stefan
2008/1/18, Frank Warmerdam <warmerdam at pobox.com>:
> Tamas Szekeres wrote:
> > Frank,
> > Mapserver is only a subset of the areas where this change would be
> > beneficial. There might be other renderers that would utilize the OGR
> > style support. I don't think this would eliminate the need of that
> > mapserver related RFC, though.
> > Would this change need an RFC on an explicit motion to vote on?
> Tamas,
> I think the notification of intent on the mailing list is sufficient
> (as you have already done).  Go ahead and make your change and if there
> are objections that arise we might reconsider.  But I don't anticipate
> any problems.
> Do please make a brief note in the method docs about this special
> behavior for an attributed named ogr_style.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080119/c34389c6/attachment.html
