[gdal-dev] OGR Select Features by Location...
Brian Hamlin maplabs at light42.com
Tue Jan 22 14:31:51 EST 2008
thats a good application of PostGIS
I think people can do it with GEOS directly, but I have not written
that myself
  -Brian
On Jan 22, 2008, at 10:40 AM, estrada.adam at gmail.com wrote:
> All,
>     I have quite a bit of LIDAR data that has been converted to point
> shapefiles.  I need to select all the points that intersect with
> another polygon shapefile and then write those features to another
> layer (shapefile).  ArcGIS will definitely do it but I am afraid that
> my machine is not beefy enough to handle LIDAR-sized datasets so I was
> wondering if anyone knew of some functionality in OGR lib that would
> do this for me?  I cannot seem to figure out how to select by location
> with the set of tools that are available i.e ogr2ogr...
> Many thanks in advance,
> AWE
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
