[gdal-dev] _gdal.py: cannot find _gdal.GDALGetFileList
Yann Chemin yann.chemin at gmail.com
Tue Jan 22 19:06:14 EST 2008
Yes Frank,
gdal-config --version
1.4.4
This is indeed an old version,
shall upgrade now,
thank you
Yann
On 22/01/2008, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Yann Chemin wrote:
> > Hello,
> > While doing this:
> >  papszFileList = _gdal.GDALGetFileList( hDataset )
> > it gave this error:
> >  AttributeError: 'module' object has no attribute 'GDALGetFileList'
> > The imported modules are:
> >  import _gdal
> >  import gdal
> >  from gdalconst import *
> > Am I missing something?
> > thank you for any suggestion...
> Yann,
> GDALGetFileList() is new to GDAL 1.5.0, and likely only exists in the
> modern Python bindings (not the antique bindings distributed in FWTools
> or built using --with-ogpython).
> Is it possible that you are using an older GDAL or a new GDAL with old
> bindings (ie. FWTools)?
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
