[gdal-dev] HDF subdatasets
Bobby Braswell rob.braswell at unh.edu
Wed Jan 23 14:32:52 EST 2008
Thanks very much.
Sorry, I saw that documentation but didn't make the connection about
how to access the various domains.
Regards,
Rob
On Jan 23, 2008, at 2:15 PM, Frank Warmerdam wrote:
> Bobby Braswell wrote:
>> Hi-
>> Is it possible to access the names of subdatasets in HDF4 files
>> using gdal-python? I can get the SDS names using gdalinfo, but
>> would like to do it from within my code.
>> For example the result of
>> D = gdal.Open('MCD43A4.A2002001.h18v01.005.2007115060137.hdf')
>> produces some dictionaries within D containing metadata
>> information, but I can't find the subdataset names anywhere, e.g.,
>> 'HDF4_EOS:EOS_GRID:"MCD43A4.A2002001.h18v01.005.2007115060137.hdf":Na
>> dir_Reflectance_Band1'
> Bobby,
> You should be able to fetch the subdataset metadata using:
>  sdlist = D.GetMetadata( 'SUBDATASETS' )
> eg.
> >>> import gdal
> >>> D = gdal.Open('NISE_SSMIF11_19911227.HDFEOS')
> GDAL: GDALOpen(NISE_SSMIF11_19911227.HDFEOS) succeeds as HDF4.
> >>> print D.GetMetadata('SUBDATASETS')
> {'SUBDATASET_2_NAME':
> 'HDF4_EOS:EOS_GRID:"NISE_SSMIF11_19911227.HDFEOS":Northern
> Hemisphere:Age', 'SUBDATASET_4_DESC': '[721x721] Age Southern
> Hemisphere (8-bit unsigned integer)', 'SUBDATASET_4_NAME':
> 'HDF4_EOS:EOS_GRID:"NISE_SSMIF11_19911227.HDFEOS":Southern
> Hemisphere:Age', 'SUBDATASET_3_NAME':
> Hemisphere:Extent', 'SUBDATASET_2_DESC': '[721x721] Age Northern
> Hemisphere (8-bit unsigned integer)', 'SUBDATASET_1_DESC':
> '[721x721] Extent Northern Hemisphere (8-bit unsigned integer)',
> 'SUBDATASET_3_DESC': '[721x721] Extent Southern Hemisphere (8-bit
> unsigned integer)', 'SUBDATASET_1_NAME':
> Hemisphere:Extent'}
> Note, the return value is a dictionary with keys of the form
> SUBDATASET_n_NAME and SUBDATASET_n_DESC.
> You might also want to skim the portion of
>   http://www.gdal.org/gdal_datamodel.html
> with the subtitle "SUBDATASETS Domain".
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://
> osgeo.org
