[gdal-dev] General Memory/Resource leak fixes(Cleanup calls)
sanjay boddhu sanjay_ieee at yahoo.com
Thu Jan 24 04:41:45 EST 2008
Hi ,
     I have been trying to fix (or to be more appropriate, find the cleanup calls to fix) the memory and resource leaks in my application(which uses GDAL to read and write to a tif file). I have tried all the cleanup calls mentioned in the end of :
http://www.gdal.org/gdalinfo.c.html
and reduced lot of memory/resource leaks......But i still get a memory leak pointing in "GDALDataset  Create( ...)"  and few resource leaks of Mutex and TLsAlloc.
I would really appreciate if anyone can recommend the right cleanup calls for the above leaks or hint me in the right direction.
Thanks
Sanjay
"If you look at what you do not have in life, you don't have anything"
"If you look at what you have in life, you have everything"
Be a better friend, newshound, and know-it-all with Yahoo! Mobile.  Try it now.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080124/45a51d70/attachment.html
