[gdal-dev] ERDAS Imagine to ERMapper
Brent Fraser bfraser at geoanalytic.com
Thu Jan 24 18:13:55 EST 2008
Nick,
  GDAL v1.5.0 has ERmapper's ERS/BIL format built-in.  You
could try that..
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
From: <nicholas.g.lawrence at mainroads.qld.gov.au>
To: <gdal-dev at lists.osgeo.org>
Sent: Thursday, January 24, 2008 4:01 PM
Subject: [gdal-dev] ERDAS Imagine to ERMapper
> Hello,
> I have a large (19 Gigabyte) erdas imagine file which I
want to bring into
> ERMapper.
> I have downloaded the minimalist windows executables from
> http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries
> I am running windows xp with 2 GB of RAM.
> I know I should use the gdal_translate command, but I am
unsure of the best
> output format.
> ecw won't work for the file size is too large.
> I thought GTiff would work, but I can't force BIGTIFF=YES
> Is there a plain old band-interleaved-by-line format
available?
> Regards,
> nick
> WARNING: This e-mail (including any attachments) may
contain legally
> privileged, confidential or private information and may be
protected by
> copyright. You may only use it if you are the person(s) it
was intended
> to be sent to and if you use it in an authorised way.  No
one is
> allowed to use, review, alter, transmit, disclose,
distribute, print
> or copy this e-mail without appropriate authority.
> If this e-mail was not intended for you and was sent to
you by mistake,
> please telephone or e-mail me immediately, destroy any
hardcopies of
> this e-mail and delete it and any copies of it from your
computer
> system. Any right which the sender may have under
copyright law, and
> any legal privilege and confidentiality attached to this
e-mail is not
> waived or destroyed by that mistake.
> It is your responsibility to ensure that this e-mail does
not contain
> and is not affected by computer viruses, defects or
interference by
> third parties or replication problems (including
incompatibility with
> your computer system).
> Opinions contained in this e-mail do not necessarily
reflect the
> opinions of the Queensland Department of Main Roads,
Queensland
> Transport or Maritime Safety Queensland, or endorsed
organisations
> utilising the same infrastructure.
> gdal-dev mailing list
