[gdal-dev] Gdaladdo error
Coutu, Jean-François COUTUJF at dfo-mpo.gc.ca
Fri Jan 25 17:19:38 EST 2008
Hello Frank,
Thanks for the anwser... I did test it with FWTools 2.0.5 today and got the same error. I can make a bug report but the smallest file that I have that is causing the problem is about 94M...What is the best way to make it available? Can I attach it to the bug?
Thanks,
JF
-----Message d'origine-----
De : Frank Warmerdam [mailto:warmerdam at pobox.com]
Envoyé : 24 janvier 2008 21:49
À : Coutu, Jean-François
Cc : gdal-dev at lists.osgeo.org
Objet : Re: [gdal-dev] Gdaladdo error
Coutu wrote:
> Hi,
> I am trying to build overviews for 100+ geotiff and tiff files.
> Gdaladdo only screws up on a handful.
> Can anyone tell me what is wrong with my files?
> I have: GDAL 1.5.0b1, FWTools 2.0.3, released 2007/12/10
> Here is the error I get:
> gdaladdo -r average 1965_04_07_Prince_Rupert_PK00893_PK05204.TIF 2 4 8
> 16 0...10...20...30...40...50...60...70...80...90...100 - done.
> Assertion failed: tif->tif_flags&TIFF_BIGTIFF, file tif_dirwrite.c,
> line
> 2027
> This application has requested the Runtime to terminate it in an
> unusual way.
> Please contact the application's support team for more information.
Jean-François,
This looks quite serious.  Could you verify the problem still occurs with FWTools 2.0.5?  If so, can you post a bug report in the GDAL Trac and make a file demonstrating the problem available?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
