[Gdal-dev] How to use GDAL using MS VC++6
mchapman at texelinc.com mchapman at texelinc.com
Sat Jan 26 01:33:55 EST 2008
Also, do you have the gdal_i.lib and gdalxx.dll in the same directory as your vc .exe program?
Martin
Sent via BlackBerry by AT&T
-----Original Message-----
Date: Fri, 25 Jan 2008 22:19:42
To:gdal-dev at lists.osgeo.org
Subject: [Gdal-dev] How to use GDAL using MS VC++6
I was successfull in building the GDAL on windows .I could see the lib , bin
,include  etc folders in
my path  "C:\warmerda\bld"  .But when I try to use
samples(eg:-http://perrygeo.net/download/gdaldemtools_20060207.zip) provided
i get lots of linker errors(despite providing LIB,INCLUDE paths in my
project settings in Visaul studio 6/8). Can anyone explain how to utilize
GDAL libraries in MS Visual studio?
View this message in context: http://www.nabble.com/How-to-use-GDAL-using-MS-VC%2B%2B6-tp15105091p15105091.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
