[gdal-dev] FW: Problem with GDAL perl 1.5 bindings
Ethan Alpert ealpert at digitalglobe.com
Thu Jan 31 08:21:57 EST 2008
Ari,
Thanks for the response. Both suggested approaches fix the problem. I
sort of see the utility of this approach however I still believe that a
FlushCache and dereferencing a dataset object should result in the
output file being closed and in a complete state. Since the rasterband
is associated with a dataset what is the usefulness of keeping the
dadtaset and it's rasterband after its dataset has been "closed"? If you
don't dereference the bands the resulting file is not just incomplete
but wrong. Extra data gets written into the tif and the georeferncing is
overwritten.
-e
-----Original Message-----
Sent: Thursday, January 31, 2008 1:48 AM
To: Ethan Alpert
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] FW: Problem with GDAL perl 1.5 bindings
Ethan,
This is because of something, which is a good thing. You (now in 1.5)
get a reference to the dataset you create by getting its raster band.
Geo::GDAL does not destroy the dataset while there is a reference to it.
You either need to use the non-referencing version of GetRasterBand,
which is _GetRasterBand or get rid of the reference by destroying the
raster variable $b.
Best regards,
Ari
Ethan Alpert kirjoitti:
> Prior to 1.5 I'd been using the trunk version from 11/06/2007. Looking
> at gdal_wrap.cpp I see that there were two versions checked in 1.3.31
> and 1.3.30. One of these checks breaks a piece of code that worked
> fine in version 1.3.29
> The problem relates to clean up when an object is dereferenced in
perl.
> For many releases now if I created and wrote an image I would have to
> Call FlushCache **and** undef the variable referencing the GDALdataset
> inorder for all the data I wrote to actually end up in the file. This
> no longer works. Now I must exit my perl script completely for the all
> the data to be completely written.
> Below is an example of converting to grayscale. This works great if at
> the end I'm done. But this is not the case. Later in the script I call
> gdal_rasterize and the resulting file ends up not having a
> geotransform and is 3x too big. If I exit my app and call
> gdal_rasterize manually everything works correctly. This is what led
> me to believe there's been a change in the perl binding that relate to
> cleaning up and finalizing the file that now doesn't execute on
> derference but only when the perl script exits.
> On 11/06/2007 my code worked. Today with the stock 1.5 it doesn't. So
> my question is there some function to call to force the file to be
> completely written? If not is there a way to revert to the prior
> functionality. .
> $gtiff_driver = Geo::GDAL::GetDriverByName('GTiff');
> $fil = Geo::GDAL::Open("$tmp_dir/$$.tif");
> $xsize = $fil->{RasterXSize};
> $ysize = $fil->{RasterYSize};
> $tot = $xsize;
> $width = $xsize;
> $bandr = $fil->GetRasterBand(1);
> $bandg = $fil->GetRasterBand(2);
> $bandb = $fil->GetRasterBand(3);
> $output_ds= $gtiff_driver->Create("$tmp_dir/$$\_bw.tif",
> $fil->{RasterXSize}, $fil->{RasterYSize}, 1,
$Geo::GDAL::Const::GDT_Byte);
> $output_ds->SetGeoTransform($fil->GetGeoTransform);
> $output_ds->SetProjection($fil->GetProjection);
> $b = $output_ds->GetRasterBand(1);
> for($k = 0; $k < $fil->{RasterYSize}; $k++) {
> $scanliner = $bandr->ReadRaster(0,$k,$fil->{RasterXSize},1);
> $scanlineb = $bandb->ReadRaster(0,$k,$fil->{RasterXSize},1);
> $scanlineg = $bandg->ReadRaster(0,$k,$fil->{RasterXSize},1);
> @datar = unpack("C[$tot]",$scanliner);
> @datag = unpack("C[$tot]",$scanlineg);
> @datab = unpack("C[$tot]",$scanlineb);
> @datagrey = ();
> $min = 300;
> $max = -1;
> for ($i = 0; $i < scalar @datar; $i++) {
> $t = (.3 * $datar[$i] + .59 * $datag[$i] + .11 * $datab[$i]) +
.000001;
> push @datagrey, int ($t+.5);
> $ot = pack("c[$tot]", at datagrey);
> $b->WriteRaster(0,$k,$width,1,$ot);
> $output_ds->FlushCache;
> undef $output_ds;
> later I call:
> system "gdal_rasterize -i -l $$ -b 1 -burn 0 $tmp_dir/$$.shp
> $tmp_dir/$$\_bw.tif ";
> gdal-dev mailing list
Prof. Ari Jolma
Geoinformatiikka / Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
