[gdal-dev] VSIReadDir() and GDALOpenInfo
Thu Jan 31 10:12:27 EST 2008
Andrey Kiselev wrote:
> On Wed, Jan 30, 2008 at 12:00:16PM -0500, Frank Warmerdam wrote:
>> But I'm wondering if there is a fundamentally better approach to
>> scanning for the list of files in a directory, or if this is
>> inherently quite an expensive operation.  Thoughts?  Other experiences
>> on this?  Is this more of an issue with particular file systems?
> Ulrich Drepper has some insights on the issue:
>  http://udrepper.livejournal.com/18555.html
> Based on his article I see few problems with our code:
>  1. We are using readdir() instead of readdir64().
Andrey,
In the VSIReadDir() code we do not actually consult the file size so
I don't see any requirement to complicate things with the 64bit variant.
>  2. We are not checking the file type: do we really need to add
>     subdirectory names to the list?
Yes, the sibling list should contain all normal files, special files
and directories.
>  3. Directory entry names have a fixed length, so we can optimize a bit
>     by removing CPLStrdup() call.
Memory still needs to be dynamically allocated for the entry in the list
returned from ReadDir() so I don't see what you are getting at.
> Other than above it seems to be nothing to optimize in our code.
It was an informative article though I'm left with the same conclusion.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
