[gdal-dev] Import raw binary with pixel-geolocation
Andrew Brooks arb at sat.dundee.ac.uk
Tue Jul 1 06:14:30 EDT 2008
Hello
Is it possible to import/warp raw binary data which has no projection just
associated arrays of latitude/longitude for each pixel?
How about if the latitude/longitude arrays were sub-sampled?  For example
MODIS 250m resolution has coordinates at 1000m resolution.
Would it be easier if I converted the data into HDF format first?  If so,
what SD names does the HDF importer use when looking for latitude and
longitude geolocation arrays?
Andrew
