[gdal-dev] Re: fwtools linux
Gregor Mosheh gregor at hostgis.com
Sat Jul 5 15:41:27 EDT 2008
Oops; I had meant to email off-list.
Frank Warmerdam wrote:
> It isn't the lack of a server that is the problem.  It is the fact that
> I've now had to transition to a newer server with newer tools versions
> I have to update lots of bits and pieces to put together a working
> distribution.
Oy, tell me about it.
> For the time being I'm putting much of my packaging effort into OSGeo4W
> so I just am not making the day or so of work it will likely take to get
> FWTools for linux working again.
OSGeo4W? Is that the new name for MS4W? Very nice.
> Other than the lack of OpenEV, I would encourage folks to use other
> Linux builds such as FGS or the DebianGIS binaries in the meantime.
Fair enough. Thanks for the tip.
Gregor Mosheh / Greg Allensworth    BS, A+, Network+, Security+, Server+
System Administrator, Lead Programmer
HostGIS development & hosting services, http://www.HostGIS.com/
"Remember that no one cares if you can back up,
  only if you can restore." - AMANDA
