[gdal-dev] Process many DEM's into 1
Matt Wilkie matt.wilkie at gov.yk.ca
Tue Jul 8 16:44:27 EDT 2008
Hi Courtney, Oliver,
 > I would try to do:
 > gdalwarp <file1> <file2> ... <outputfile>
Depending on the source data, this may not handle overlap between tiles
very well. For the canadian CDED dems from geobase.ca I had to use the
src and dstnodata options:
   gdalwarp -srcnodata -32767 -dstnodata -32767 ...etc
It can also speed up things dramatically to use the -wm and -multi
options (working memory and multithreaded).
Some scripts I used are at
http://sydney.freeearthfoundation.com/mattwilkie/draft/canada_50k_dem/scripts/
(Unlike the script there, don't use "-co compress=lzw" though! it will
make your images larger than if no compression is used.
http://trac.osgeo.org/gdal/wiki/UserDocs/GdalWarp#a-coCOMPRESSisbroken )
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
Oliver Eichler wrote:
> On Tuesday, 8. July 2008 17:42:07 Courtney Schitka wrote:
>> Hi List,
>> You guys have been great. Today my problem is I've downloaded 400 dem's
>> from an FTP server I was wondering if there was anyway using FWTools or
>> what have you, to turn many dem's into 1 dem. The files are seperate and
>> together cover one contiguous area. Rather then opening every one I would
>> like to turn them into 1 file so all i have to do is open 1 of them.
> I would try to do:
> Oliver
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
