[gdal-dev] CoordinateTransformation towgs84 parameter
Wed Jul 9 08:35:43 EDT 2008
Mendizabal Vicente, Ainhoa wrote:
> Hi all,
> I just want to know if the “OGRCreateCoordinateTransformation” function
> takes into account the names of the datums involved (specified in the
> WKT), or if it is necessary to specify the TOWGS84 parameter for each
> Coordinate System. In this case, where I can get this parameter for each
> datum?
Ainhoa,
The names of datums are generally not significant to OGR, with a few
exceptions (ie. special rules for recognising NAD27 for instance).
Generally, with the exception of NAD27, you should attempt to provide a
TOWGS84 parameter if you want datum shifts.
Finding appropriate values is difficult.  The EPSG database has some (often
multiple possibilities per datum).  There are a variety of other sources,
such as national mapping agencies.  Which value is best often depends on
the region of interest within the applicable area of the datum.
I have no good answer.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
