[gdal-dev] transforming epsg:900913 to Calif. Teale Albers y-shift
	problem
    Jennifer Strahan
    jennifer at greeninfo.org
    Wed Jul  9 23:03:34 EDT 2008
Hello All,
I'm using OpenLayers and Featureserver to draw shapes on top of a Google
base map and save into my PostGIS database.  The geometry column is
using ESPG: 900913.  Now, I'd like to export out a shapefile for use in
ArcGIS, using the California Teale Albers projection. I tried the
following and am ending up with an ~18,000 meter Y shift and a little
bit of an X shift.
$ret = shell_exec ("ogr2ogr -f 'ESRI Shapefile'
/var/tmp/shapefile/parkinfo_edits.shp 'PG:dbname=parkinfo_edit
host=localhost user=pgsql password=*****' -s_srs EPSG:900913 -sql
'Select * from holdingsfeb08_new' -t_srs '+proj=aea +lat_1=34.00
+lat_2=40.50 +lat_0=0.00 +lon_0=-120.00 +x_0=0.000 +y_0=-4000000.000
+ellps=GRS80 +units=m +datum=NAD83'");
I went to spatialreference.org and have been trying various
projections.  In each case I'm getting the same results.
Do you have any suggestions?
Thanks,
Jennifer
