[gdal-dev] copy features in python ogr
Bobby H. Braswell rob.braswell at unh.edu
Thu Jul 10 10:02:43 EDT 2008
I'm trying to make a script that will read a single-polygon shapefile,
apply a buffer to the polygon (using shapely) and then write out a new
file with two polygon features representing the original and the
buffered region. Rather than creating a new polygon shapefile from
scratch, I'm wondering if I can just make a copy of the contents of
the source file (one layer, one feature), add the new feature, then
write the new contents (one layer, two features) to an output shapefile.
I'm looking at the "CopyLayer" method of the source file, but can't
seem to get the inputs right, and anyway I'm not sure if that's the
way to go. Any suggestions would be appreciated.
Thanks very much,
Rob Braswell
University of New Hampshire
