[Gdal-dev] Install Error occuring in swig/python
ChiefDan dan at inlet.geol.sc.edu
Thu Jul 10 15:51:20 EDT 2008
I found a solution to my issue. What I ended up doing was editing the
GNUMakefile in swig/python and changing PYTHON=python to
PYTHON=/home/dramage/local/bin/python.
It seems like there needs to be a way to specify an alternate path to use
for python if it is not in the default directory.
View this message in context: http://www.nabble.com/Install-Error-occuring-in-swig-python-tp18385793p18390509.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
