[gdal-dev] densify line?
Matt Wilkie matt.wilkie at gov.yk.ca
Thu Jul 10 17:06:03 EDT 2008
wow, talk about speed.
thanks Even!
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
Even Rouault wrote:
> For your information, I've just added in GDAL trunk a segmentize() method to
> OGRGeometry and a "-segmentize" option to ogr2ogr.
> Le Thursday 10 July 2008 18:58:46 Matt Wilkie, vous avez écrit :
>> Hello All,
>> Does ogr have a densify line option or utility?
>> The goal is to densify (add vertices at regular intervals) to a 1
>> dergree by 1 degree fishnet grid before projecting from WGS84 to UTM (or
>> whatever) so the result follows earth curvature rather then jumping
>> straight from corner point to corner point.
>> I could use Arcinfo DENSIFYARC, but would like to avoid having to
>> convert to a coverage if I can.
>> thanks,
