[Gdal-dev] Workaround for DataSet.GetGCPs from c#/java?
fevans fevans at harris.com
Fri Jul 11 13:45:17 EDT 2008
I see the milestone for this is GDAL 1.5.3.
http://trac.osgeo.org/gdal/ticket/1677
Is there any other way to access the GCPs in java/c#? For example, would it
be possible to construct a "SWIGTYPE_p_int", and a "SWIGTYPE_p_GDAL_GCP[]" ?
I experimented a little but sort of hit a swig wall.
BTW, keep up the great work Tamas.
Tamas Szekeres wrote:
> 2007/6/19, Jason Beverage <jbeverage at prologic-inc.com>:
>> Hi all,
>> It seems like the signature for DataSet.GetGCPs is incorrect in the C#
>> bindings.  It is currently:
>> void DataSet.GetGCPs(SWIGTYPE_p_int nGCPs, SWIGTYPE_p_p_GDAL_GCP pGCPs)
>> It seems like it should be:
>> GCP[] Dataset.GetGCPs();
>> Should I open a ticket?
>> Thanks,
>> Jason
> Yes please, and assign the ticket to the CSharpBindings component
> Best regards,
> Tamas Szekeres
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
View this message in context: http://www.nabble.com/DataSet.GCPs-Method-in-C--Bindings-tp11197327p18409180.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
