[gdal-dev] Correct gdalwarp usage from UTM to Equidistant Cylindrical Projection
Christopher Hunt huntc at internode.on.net
Sun Jul 13 04:35:53 EDT 2008
Hi there,
First off, wow, gdal is great.
I'm obviously new to gdal so I'm hoping that you'll put up with what
I'm sure will be regarded as a "newbie" style of question.
I have an image from Terraserver that is in a UTM 30 projection. I
need to convert it to a Equidistant Cylindrical Projection. I would
like to verify that I'm using the gdalwarp command properly so I'm
helping that you can help me.
Here's the image info I have;
> Image Information:
> Date Taken: 1/1/1999
> Native Resolution: 15
> File Size: 3000 x 3000 (9.0 megapixels)
> Image Area: 18,225.00 sq km
> Coordinate Information:
> Center point Latitude: 51.46660 (51∞ 27' 60")
> Center point Longitude: -0.44990 (0∞ 26' 60")
> Upper left corner Latitude: 52.09038 (52∞ 5' 25")
> Upper left corner Longitude: -1.39985 (-1∞ 23' 59")
> Lower right corner Latitude: 50.83562 (50∞ 50' 8")
> Lower right corner Longitude: 0.47438 (0∞ 28' 28")
> Geo-reference Information:
> Projection: UTM Zone 30
> Datum: WGS 84
> Image Units: Meters
Furthermore, here's the associated tfw file contents:
> 45.000000
> 0.000000
> 0.000000
> -45.000000
> 609626.000120
> 5772299.000249
FInally here's the command I think I should be using:
> gdalwarp -s_srs '+proj=utm +zone=30 +datum=WGS84 +x_0=609626.000120
> +y_0=5772299.000249' -t_srs '+proj=eqc' -dstalpha -multi
> 169460-65786.tif out.tif
I certainly get a resultant image but I'm not experienced enough with
cartography to understand whether the image is correct.
One thing that does confuse me slightly is that the centre lat/long in
the resultant image is not the same as in the source image... I would
have expected that they would be, or at least that the top left corner
(which is what I thinking the northerly and easterly parameters point
to) should be the same.
Another thing: I would expect to specify either a scale, a resolution
or the other corner of the image... do I need to include something
more in the command for this?
Thanks for any enlightenment. I'm fascinated by cartography and relish
the prospect of learning gdal more.
Kind regards,
Christopher
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080713/4aa2dde3/attachment.html
