[gdal-dev] Should we use boolean type at the SWIG interface?
Sun Jul 13 13:08:00 EDT 2008
Tamas Szekeres wrote:
> Devs,
> By using boolean type in the SWIG bindings I currently get a number if
> warnings when compiling the generated code:
> http://buildbot.osgeo.org:8500/builders/szekerest-vc71-full/builds/36/steps/csharp-make/logs/stdio
> Since there are no boolean value exposed by the gdal dll I suppose we
> can use integers instead of booleans at the wrappers as well.
> Any objection to relpace 'bool' with 'int' in ogr.i?
Tamas,
I believe it would be simplest to expose boolean results as a int.
I see that the C API already treats the return result of TestCapability()
as an int.  I'm not sure why it was done differently in the swig include
file.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
