[Gdal-dev] Using VRT to project/rotate tiff files on-the-fly
David M Nelson dnelson99 at gmail.com
Mon Jul 14 18:18:59 EDT 2008
I have a series of unprojected, single-frame images.  We want to be able to
project them on-the-fly by generating a VRT file for each image.  However,
none of the images are oriented north-up--they are all uniquely oriented
because of the flightpath taken by the platform during the time of
acquisition.  I have not been able to find a way to generate a VRT that
takes orientation into account.  I tried to use the X-rotation and the
Y-rotation, but this completely distorts the image setting some of the
coordinate values to 35,000+ deg.  I think that the orientation values are
supposed to be for the reference frame anyway and not the images (?).
So my question is: is there a way to generate a VRT file which will project
and orient correctly an unprojected image?
Thanks for your help!
David
View this message in context: http://www.nabble.com/Using-VRT-to-project-rotate-tiff-files-on-the-fly-tp18448351p18448351.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
