[Gdal-dev] GDAL 1.5.1 distribution - something's missing
Maksim Sestic max at geoinova.com
Thu Jul 17 10:27:34 EDT 2008
One more note: gdal_wrap.dll is there, sitting at the same folder.
I didn't rebuild GDAL libs, I simply unistalled VS 2005 and installed VS
2008. Then it stopped working.
Regards,
Maksim Sestic
Maksim Sestic wrote:
> Hi all,
> I just had a working GDAL 1.5.1 copy (custom build), then I uninstalled VS
> 2005 along with various support libraries for this and that (installed as
> VS 2005 prerequisite) and installed VS 2008. GDAL is not working anymore:
> when I try to run any of the gdal*.exe files (i.e. gdal_translate.exe) it
> stops with following message:
> The system cannot execute the specified program.
> If I try utilizing GDAL managed wrappers via .NET it throws following
> exception:
> ************** Exception Text **************
> System.TypeInitializationException: The type initializer for
> 'OSGeo.GDAL.Gdal' threw an exception. --->
> 'OSGeo.GDAL.GdalPINVOKE' threw an exception. --->
> 'SWIGExceptionHelper' threw an exception. --->
> System.DllNotFoundException: Unable to load DLL 'gdal_wrap': This
> application has failed to start because the application configuration is
> incorrect. Reinstalling the application may fix this problem. (Exception
> from HRESULT: 0x800736B1)
>    at
> OSGeo.GDAL.GdalPINVOKE.SWIGExceptionHelper.SWIGRegisterExceptionCallbacks_Gdal(ExceptionDelegate
> applicationDelegate, ExceptionDelegate arithmeticDelegate,
> ExceptionDelegate divideByZeroDelegate, ExceptionDelegate
> indexOutOfRangeDelegate, ExceptionDelegate invalidCastDelegate,
> ExceptionDelegate invalidOperationDelegate, ExceptionDelegate ioDelegate,
> ExceptionDelegate nullReferenceDelegate, ExceptionDelegate
> outOfMemoryDelegate, ExceptionDelegate overflowDelegate, ExceptionDelegate
> systemExceptionDelegate)
>    at OSGeo.GDAL.GdalPINVOKE.SWIGExceptionHelper..cctor()
>    --- End of inner exception stack trace ---
>    at OSGeo.GDAL.GdalPINVOKE.SWIGExceptionHelper..ctor()
>    at OSGeo.GDAL.GdalPINVOKE..cctor()
>    at OSGeo.GDAL.GdalPINVOKE.TermProgress_get()
>    at OSGeo.GDAL.Gdal..cctor()
>    at OSGeo.GDAL.Gdal.AllRegister()
> Obviously failing at Gdal.AllRegister(), although the same setup works on
> the other machine having VS 2005 installed. I guess I'm missing some
> VC...something library - but, which one?
> Regards,
> Maksim Sestic
View this message in context: http://www.nabble.com/GDAL-1.5.1-distribution---something%27s-missing-tp18509648p18509746.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
