[Gdal-dev] GDAL 1.5.1 distribution - something's missing
Maksim Sestic max at geoinova.com
Thu Jul 17 10:43:02 EDT 2008
Hi Mateusz,
In all the horror I simply forgot about dependacy walker :-) Since I'm
maintaining several GDAL installations I simply though that something Got
Broken (tm) :-)
Now, here's the missing libs:
MSVCP80D.DLL
MSVCR80.DLL
MSVCR80D.DLL
DWMAPI.DLL
I'll check both Microsoft Visual C++ 2005 Redistributable Package and
Microsoft Visual C++ 2005 SP1 Redistributable Package to see which one's the
right one.
Will report which one works, other folks switching to VS 2008 may find it
useful.
Regards,
Maksim Sestic
Mateusz Loskot wrote:
> Maksim Sestic wrote:
>> Obviously failing at Gdal.AllRegister(), although the same setup works on
>> the other machine having VS 2005 installed. I guess I'm missing some
>> VC...something library - but, which one?
> Maksim,
> Try to use Dependency Walker (http://www.dependencywalker.com/), also
> known as depende.exe in bin directory of Visual Studio, to find what DLL
> files can not be found.
> I'm quite sure that you don't have C/C++ run-time libraries actually
> uninstalled after you've removed Visual C++ 2005.
> You can download the redistributable package from microsoft.com:
> 1) if you didn't use SP1 for Visual Studio 2005
> http://www.microsoft.com/downloads/details.aspx?FamilyId=32BC1BEE-A3F9-4C13-9C99-220B62A191EE&displaylang=en
> 2) if you did use SP1 for VS2005
> http://www.microsoft.com/downloads/info.aspx?na=47&p=1&SrcDisplayLang=en&SrcCategoryId=&SrcFamilyId=32bc1bee-a3f9-4c13-9c99-220b62a191ee&u=details.aspx%3ffamilyid%3d200B2FD9-AE1A-4A14-984D-389C36F85647%26displaylang%3den
> I'm not sure if these links won't get broken, but if they will,
> just google for:
> or
> Greetings
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> Mateusz Loskot
View this message in context: http://www.nabble.com/GDAL-1.5.1-distribution---something%27s-missing-tp18509648p18510116.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
