[gdal-dev] Oracle Connection issues
Thu Jul 17 14:45:49 EDT 2008
Clay, Bruce wrote:
> 2. There seems to be a long pause when I connect to Oracle.  I used the
> debugger to follow the process and it looks like an internal structure
> is created in GDAL memory space that contains information about all of
> the tables in Oracle including the field names and data types.  We have
> a database with several tables so this takes a while to build.  Is there
> a way to get GDAL to do a quick connect without building this structure
> every time I connect?
Per the OCI driver docs:
When opening a database, it's name should be specified in the form
"OCI:userid/password at database_instance:table,table".  The list of tables
is optional.  The database_instance portion may be omitted
when accessing the default local database instance.<p>
If you provide an explicit list of tables of interest, only those will
be converted into OGR layers, which can greatly accelerate the time to
establish access to the database.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
