[Gdal-dev] Workaround for DataSet.GetGCPs from c#/java?
fevans fevans at harris.com
Mon Jul 21 10:27:57 EDT 2008
Tamas:
Works great. Thanks!!!
http://download.osgeo.org/gdal/daily/gdalsvn-stable-20080721.zip
Tamas Szekeres wrote:
> FYI: I've just added the implementation for the Dataset.GetGCPs,
> Dataset.SetGCPs and GCPsToGeotransform for the C# bindings in the
> SVN-trunk. I've added the use cases for these functions in the
> GDALWrite and GDALInfo sample applications. Will also apply these in
> the stable branch soon.
> Best regards,
> Tamas
> 2008/7/11 fevans <fevans at harris.com>:
>> OK, c# works for me. Will be on task all weekend so let me know if I can
>> help.
>>> Hi,
>>> This will requre a bindings specific implementation, I'll be trying to
>>> implement something in this weekend if this issue is pressing for you.
>>> But it will only affect the c# interface, though
>>> Best regards,
>>> Tamas
>>>> I see the milestone for this is GDAL 1.5.3.
>>>> http://trac.osgeo.org/gdal/ticket/1677
>>>> Is there any other way to access the GCPs in java/c#? For example,
>>>> would
>>>> it
>>>> be possible to construct a "SWIGTYPE_p_int", and a
>>>> "SWIGTYPE_p_GDAL_GCP[]" ?
>>>> I experimented a little but sort of hit a swig wall.
>>>> BTW, keep up the great work Tamas.
>>>>> 2007/6/19, Jason Beverage <jbeverage at prologic-inc.com>:
>>>>>> Hi all,
>>>>>> It seems like the signature for DataSet.GetGCPs is incorrect in the
>>>>>> C#
>>>>>> bindings.  It is currently:
>>>>>> void DataSet.GetGCPs(SWIGTYPE_p_int nGCPs, SWIGTYPE_p_p_GDAL_GCP
>>>>>> pGCPs)
>>>>>> It seems like it should be:
>>>>>> GCP[] Dataset.GetGCPs();
>>>>>> Should I open a ticket?
>>>>>> Thanks,
>>>>>> Jason
>>>>> Yes please, and assign the ticket to the CSharpBindings component
>>>>> Best regards,
>>>>> Tamas Szekeres
>>>>> _______________________________________________
>>>>> Gdal-dev mailing list
>>>>> Gdal-dev at lists.maptools.org
>>>>> http://lists.maptools.org/mailman/listinfo/gdal-dev
>>>> View this message in context:
>>>> http://www.nabble.com/DataSet.GCPs-Method-in-C--Bindings-tp11197327p18409180.html
>>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> http://www.nabble.com/DataSet.GCPs-Method-in-C--Bindings-tp11197327p18409442.html
View this message in context: http://www.nabble.com/DataSet.GCPs-Method-in-C--Bindings-tp11197327p18569794.html
