[Gdal-dev] c# Bindings in Mono/Linux
Tamas Szekeres szekerest at gmail.com
Mon Jul 21 17:03:42 EDT 2008
Frank,
I've committed in the SVN trunk to produce well formed xml with the
development version. However I doubt if it causes this problem.
Probably your environment settings like incorrect LD_LIBRARY_PATH
prevents from loading the gdal so or the related so-s (like proj).
At the buildbot configurations those pathes have been set manually to
the correct directories.
Best regards,
Tamas
2008/7/21 fevans <fevans at harris.com>:
> Tamas, with regards to mono/gdal bindings, I suspect I'm doing something
> wrong in the build process. Clearly the buildbots are passing.
> One item that's been bothering me is line 50 of "swig\csharp\GNUMakefile"
> Its generating a config-xml wrapper for the dll, but thet XML is mal-Formed.
> echo "<dllmap dll=\""$*"_wrap\" target=\""$@"\">" >> $*_csharp.dll.config
> Generates: <dllmap dll="gdal_wrap" target="libgdalcsharp.la">
> Should be: <dllmap dll="gdal_wrap" target="libgdalcsharp.la" />
> So either these wrappers are not used, or I'm digging in the wrong place.
> The nightly builds at "http://buildbot.osgeo.org/gdal-full/" are still
> inaccessible.
> ./mkinterface.sh
> make -f GNUmakefile
> make test
> LC_ALL=C mono createdata.exe Data pointlayer
> Unhandled Exception: System.TypeInitializationException: An exception was
> thrown by the type initializer for OSGeo.OGR.gr --->
> System.TypeInitializationException: An exception was thrown by the type
> initializer for OSGeo.OGR.OgrPINVOKE --> System.TypeInitializationException:
> An exception was thrown by the type initializer for SWIGExceptionHelper --->
> Systm.DllNotFoundException: libogrcsharp.la
>  at (wrapper managed-to-native)
> SWIGExceptionHelper:SWIGRegisterExceptionCallbacks_Ogr
> (OSGeo.OGR.OgrPINVOKE/SWIGExcepionHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptinHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHeper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelpr/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelperExceptionDelegate)
>  at OSGeo.OGR.OgrPINVOKE+SWIGExceptionHelper..cctor () [0x00000] --- End of
> inner exception stack trace ---
>  at OSGeo.OGR.OgrPINVOKE..cctor () [0x00000] --- End of inner exception
> stack trace ---
>  at OSGeo.OGR.Ogr..cctor () [0x00000] --- End of inner exception stack
> trace ---
>  at CreateData.Main (System.String[] args) [0x00000]
> make: *** [test] Error 1
> Tamas Szekeres wrote:
>> 2008/6/11 Evans, Frank <fevans at harris.com>:
>>> Tamas, thanks for the test-results link. I had read that tests were
>>> passing, but the log-detail provided a lot of useful info. I will try
>>> SWIG 1.3.31 this weekend, and let everyone know. I can't switch mono
>>> versions, at least not easily. Are the library outputs for the automated
>>> builds accessible?
>> The build directory of the linux builders used to be accessible from
>> the following link:
>> http://buildbot.osgeo.org/gdal-quick/
>> But it seems like having a permission problem at the moment.
>>> I know I'm asking for speculation, but do you think there's a
>>> 32-bit/64-bit issue?
>> I`ve been trying on debian AMD64 as I`ve noted in my previous post so
>> I doubt that this is a 64 bit OS related issue.
>> The version of swig and mono might even more be an issue.
>> Best regards,
>> Tamas
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> View this message in context: http://www.nabble.com/c--Bindings-in-Mono-Linux-tp17709337p18570865.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
