[Gdal-dev] ./configure options
Tamas Szekeres szekerest at gmail.com
Tue Jul 22 09:51:03 EDT 2008
Frank,
According to the previous posts you might want to check the followings:
1. Do the dependent libraries  (like libogrcsharp, gdal, proj, ..)
available to load by the system. See the LD_LIBRARY_PATH settings.
2. You can also make a test with a previous version of mono. We use
1.2.2.1 on the buildbot machine. There have been a couple of issues
reported with some of the newer versions as far as I remember.
3. You could also try using SWIG 1.3.31 like at the buildbot slaves,
but I hope the newer versions will also work.
4. You might want to try using the --without-libtool configure option,
though I'm not aware of much issues with the libtool builds (the
epimetheus slave is configure with libtool on osx) but it might also
be an issue, definitely.
Best regards,
Tamas
2008/7/22 fevans <fevans at harris.com>:
> This message is related to the following thread.
> http://www.nabble.com/c--Bindings-in-Mono-Linux-td17709337.html
> Trying to get the c# bindings working in mono linux. The buildbots are
> working, so clearly its a configuration or env issue on my end. Does anyone
> have any general configuration advice on this? My config summary is listed
> below. The items which concern me most are:
> SWIG Bindings:          no
> Statically link PROJ.4:    no
> enable pthread support:    no
> Based on all my experience, the SWIG bindings don't build automatically. But
> I'm not sure if this is normal.
> GDAL is now configured for x86_64-unknown-linux-gnu
>  Installation directory:    /ssa/users/fevans/gdal-1.5.3dev
>  C compiler:                gcc -g -O2
>  C++ compiler:              g++ -g -O2
>  LIBTOOL support:           yes
>  LIBZ support:              external
>  GRASS support:             no
>  CFITSIO support:           no
>  PCRaster support:          internal
>  NetCDF support:            no
>  LIBPNG support:            external
>  LIBTIFF support:           external (BigTIFF=no)
>  LIBGEOTIFF support:        internal
>  LIBJPEG support:           internal
>  LIBGIF support:            internal
>  OGDI support:              no
>  HDF4 support:              no
>  HDF5 support:              no
>  Kakadu support:            no
>  JasPer support:            no
>  ECW support:               no
>  MrSID support:             no
>  GRIB support:              no
>  cURL support (wms/wcs/...):yes
>  PostgreSQL support:        no
>  MySQL support:             no
>  Xerces-C support:            no
>  Expat support:             yes
>  ODBC support:              no
>  PGeo support:              no
>  OCI support:               no
>  SDE support:               no
>  DODS support:              no
>  SQLite support:            no
>  DWGdirect support          no
>  PANORAMA GIS support:      no
>  INFORMIX DataBlade support:no
>  GEOS support:              yes
>  Old-gen python          no
>  SWIG Bindings:          no
>  enable OGR building:       yes
>  hide internal symbols:     no
> View this message in context: http://www.nabble.com/.-configure-options-tp18586854p18586854.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
