[gdal-dev] Bindings for the histogram method of band
Ari Jolma ari.jolma at tkk.fi
Tue Jul 22 10:48:27 EDT 2008
The trac.osgeo.org does not answer so I'll put this here.
Hobu, would it be ok to have (int len, int *output) typemap. They can be
used in GetHistogram method like this (note that the API is same for C#
but it must use different typemaps. From Band.i:
#ifndef SWIGCSHARP
%feature( "kwargs" ) GetHistogram;
%apply (int len, int *output) {(int nBuckets, int *panHistogram)};
%apply (IF_ERROR_RETURN_NONE) { (CPLErr) };
#else
%apply (int inout[ANY]) {int *panHistogram};
#endif /* SWIGCSHARP */
  CPLErr GetHistogram( double dfMin=-0.5,
                     double dfMax=255.5,
                     int nBuckets=256, /* as in GDAL docs */
                     int *panHistogram = NULL,
                     int bIncludeOutOfRange = 0,
                     int bApproxOk = 1,
                     GDALProgressFunc callback = NULL,
                     void* callback_data=NULL ) {
    return GDALGetRasterHistogram(  self,
                                dfMin,
                                dfMax,
                                nBuckets,
                                panHistogram,
                                bIncludeOutOfRange,
                                bApproxOk,
                                callback,
                                callback_data);
#ifndef SWIGCSHARP
%clear (int nBuckets, int *panHistogram);
%clear (CPLErr);
#else
%clear int *panHistogram;
And the typemaps for Perl: Note the slight abuse of check for malloc.
This is tested and works.
%typemap(in,numinputs=1) (int len, int *output)
  /* %typemap(in,numinputs=1) (int len, int *output) */
  $1 = SvIV($input);
%typemap(check) (int len, int *output)
  /* %typemap(check) (int len, int *output) */
  if ($1 < 1) $1 = 1; /* stop idiocy */
  $2 = (int *)CPLMalloc( $1 * sizeof(int) );
%typemap(argout,fragment="CreateArrayFromIntArray") (int len, int *output)
  /* %typemap(argout) (int len, int *output) */
  $result = CreateArrayFromIntArray( $2, $1 );
  argvi++;
%typemap(freearg) (int len, int *output)
  /* %typemap(freearg) (int len, int *output) */
  CPLFree($2);
Ari
Prof. Ari Jolma
Geoinformatiikka / Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
