[Gdal-dev] c# Bindings in Mono/Linux
Tamas Szekeres szekerest at gmail.com
Tue Jul 22 10:48:32 EDT 2008
Frank,
It looks like either libgdalcsharp.la or one of it's dependencies is
not available to load, or incorrect version can be loaded with the
current LD_LIBRARY_PATH setting. Please check that the same version of
gdal is loading that the csharp bindings have been compiled against.
Best regards,
Tamas
2008/7/22 Evans, Frank <fevans at harris.com>:
> I agree the dll.config isn't the main issue. I've tried renaming files,
> linking statically, linking dynamically. After a while, experimentation
> makes the baseline suspect, so I blast it and start over. Its definitely
> something on my end. Some basic mistake. I need to get more
> swig-knowledge.
> Thanks again for all your help. BTW, I ran "strace -e trace=open mono
> GDALInfo.exe ..."
> open("libgdalcsharp.la", O_RDONLY|O_LARGEFILE) = 4
> open("./.libs/libgdalcsharp.so.1", O_RDONLY) = 4
> -----Original Message-----
> From: Tamas Szekeres [mailto:szekerest at gmail.com]
> Sent: Monday, July 21, 2008 5:04 PM
> To: Evans, Frank
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [Gdal-dev] c# Bindings in Mono/Linux
> Frank,
> I've committed in the SVN trunk to produce well formed xml with the
> development version. However I doubt if it causes this problem.
> Probably your environment settings like incorrect LD_LIBRARY_PATH
> prevents from loading the gdal so or the related so-s (like proj).
> At the buildbot configurations those pathes have been set manually to
> the correct directories.
> Best regards,
> Tamas
> 2008/7/21 fevans <fevans at harris.com>:
>> Tamas, with regards to mono/gdal bindings, I suspect I'm doing
> something
>> wrong in the build process. Clearly the buildbots are passing.
>> One item that's been bothering me is line 50 of
> "swig\csharp\GNUMakefile"
>> Its generating a config-xml wrapper for the dll, but thet XML is
> mal-Formed.
>> echo "<dllmap dll=\""$*"_wrap\" target=\""$@"\">" >>
> $*_csharp.dll.config
>> Generates: <dllmap dll="gdal_wrap" target="libgdalcsharp.la">
>> Should be: <dllmap dll="gdal_wrap" target="libgdalcsharp.la" />
>> So either these wrappers are not used, or I'm digging in the wrong
> place.
>> The nightly builds at "http://buildbot.osgeo.org/gdal-full/" are still
>> inaccessible.
>> ./mkinterface.sh
>> make -f GNUmakefile
>> make test
>> LC_ALL=C mono createdata.exe Data pointlayer
>> Unhandled Exception: System.TypeInitializationException: An exception
> was
>> thrown by the type initializer for OSGeo.OGR.gr --->
>> System.TypeInitializationException: An exception was thrown by the
> type
>> initializer for OSGeo.OGR.OgrPINVOKE -->
>> An exception was thrown by the type initializer for
> SWIGExceptionHelper --->
>> Systm.DllNotFoundException: libogrcsharp.la
>>  at (wrapper managed-to-native)
>> SWIGExceptionHelper:SWIGRegisterExceptionCallbacks_Ogr
> (OSGeo.OGR.OgrPINVOKE/SWIGExcepionHelper/ExceptionDelegate,OSGeo.OGR.Ogr
> PINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGE
> xceptinHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelper
> /ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionelper/ExceptionDele
> gate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelper/ExceptionDelegate,OSGeo.OG
> R.OgrPINVOKE/SWIGExceptionHeper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/S
> WIGExceptionHelper/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionH
> elpr/ExceptionDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelper/Exceptio
> nDelegate,OSGeo.OGR.OgrPINVOKE/SWIGExceptionHelperExceptionDelegate)
>>  at OSGeo.OGR.OgrPINVOKE+SWIGExceptionHelper..cctor () [0x00000] ---
> End of
>> inner exception stack trace ---
>>  at OSGeo.OGR.OgrPINVOKE..cctor () [0x00000] --- End of inner
> exception
>> stack trace ---
>>  at OSGeo.OGR.Ogr..cctor () [0x00000] --- End of inner exception stack
>> trace ---
>>  at CreateData.Main (System.String[] args) [0x00000]
>> make: *** [test] Error 1
>> Tamas Szekeres wrote:
>>> 2008/6/11 Evans, Frank <fevans at harris.com>:
>>>> Tamas, thanks for the test-results link. I had read that tests were
>>>> passing, but the log-detail provided a lot of useful info. I will
> try
>>>> SWIG 1.3.31 this weekend, and let everyone know. I can't switch mono
>>>> versions, at least not easily. Are the library outputs for the
> automated
>>>> builds accessible?
>>> The build directory of the linux builders used to be accessible from
>>> the following link:
>>> http://buildbot.osgeo.org/gdal-quick/
>>> But it seems like having a permission problem at the moment.
>>>> I know I'm asking for speculation, but do you think there's a
>>>> 32-bit/64-bit issue?
>>> I`ve been trying on debian AMD64 as I`ve noted in my previous post so
>>> I doubt that this is a 64 bit OS related issue.
>>> The version of swig and mono might even more be an issue.
>>> Best regards,
>>> Tamas
>>> gdal-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> View this message in context:
> http://www.nabble.com/c--Bindings-in-Mono-Linux-tp17709337p18570865.html
>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
